Beiträge von Locke1405
    Garmin BaseCamp Version 4.0.5 steht zum Download bereit.
    Guckst Du hier!
    Change History
    Changes made from version 4.0.4 to 4.0.5:
    Fixed issue when changing list or folder selection with nearest results shown on the map.
    Fixed issue when changing list or folder selection while in the process of drawing a route.
    Fixed issue with find toolbar visibility not being remembered between application runs.
    Garmin BaseCamp Version 4.0.4 steht zum Download bereit.
    Guckst Du hier!
    Change History
    Changes made from version 4.0.2 to 4.0.4:
    Fixed some issues with publishing adventures.
    Fixed an issue with remembering the layout of the data and map panels.
    Fixed an issue with remembering the positioning of the toolbars.
    Fixed some layout issues in Windows XP.
    Fixed ordering of photos during adventure playback.
    Fixed various stability issues with route properties.
    Fixed issues with the route and track join.
    Fixed some device and adventure transfer issues.
    Fixed issue with gdb and kml import.
    Fixed issues with adventure playback.
    Fixed an issue with exporting waypoints with dog icons.
    Fixed an issue where orphaned route via point would remain on the map in certain cases.
    Fixed an issue where geotagged photos were not being cleaned up after deletion.
    Fixed an issue with the notes tab where links where not being stored properly.
    Fixed various other stability issues.
    Improved speed for displaying the properties of an adventure for the first time.
    Improved transition when entering/leaving adventure playback mode.
    Ich würde es erstmal mit auf-polstern und um-modellieren der Sozius-Sitzbank bei einem guten Sattler versuchen. Da gibt es bestimmt eine Möglichkeit, dass auch Dein Frauchen wieder glücklich wird. Gegebenenfalls ist auch noch eine Heckhöherlegung eine Überlegung wert.
    Das ist doch kein Problem. Auf dem ersten Foto von Volkeredo ganz unten rechts erkennt man doch, dass alles dafür getan wird, die Piste für Motorradfahrer freizuhalten! :mrgreen: :mrgreen: :mrgreen:
    Der muss nur morgens bei Zeit beginnen um die 48 Kehren zu kehren. :whistle: :whistle:
    Bei uns zuhause sieht es heute fast genauso aus. Mein Pferdchen bleibt bei so einem Wetter im Stall :hand:
    Das kann ich so voll bestätigen. Ich kann mich mit meiner weltbesten Sozia sogar noch gut auf der AB bei Tempo 150km/h über das SRC-System unterhalten.
    Allerdings erst, seit ich mir die Scheibe richtig eingestellt habe. Habe mir den MRA X-creen Aufsatz "XCA" montiert und seither ist wirklich Ruhe im Helm.
